Hi all, I started winterizing our 400 yesterday using the instructions in this thread and also the manual for the Nautilus system (
https://tab-rv.vanillacommunity.com/discussion/comment/151043#Comment_151043). So far, its been very straightforward using the air coupler in the instructions provided by Fergie.
My questions are:
1. Do I really need to vent the Alde hot water coil? I have been using the HW low point drain in the Nautilus compartment and feel like I have the HW lines drained well.
2. If I understand the Alde correctly, I can use the heater side with no issues for winter camping and just leave the HW function off. Is this correct?
thanks!
I'm more familiar with the 320 without the Nautilus, but I'd be surprised if the 400 works differently. Someone else feel free to correct me if I am wrong!
This would only work where you have a hookup to drain the gray tank as you use it.
Since the TaB400 washroom is also heated, a d the black tank is under the toilet in the washroom (above the floor), add some RV antifreeze to the black, and gray tanks to get the antifreeze in the lower tank drain lines and gate valves (every night if using a hook up).
finished up winterizing our Tab yesterday using the Fergie method. Went really well. I did use the nautilus/pump to run some antifreeze into the lines. Am I right in thinking that no antifreeze was pulled into the Alde HW line?
Yes, I connect a longer pump output hose to my toilet water line to run antifreeze through both, plus it covers the dump valve. And that's after recovering the same antifreeze that I ran through the outdoor shower, so it is recycled through multiple plumbing systems. All are blown out with compressed air first, so this is for extra protection.
Here are the photos..
https://tab-rv.vanillacommunity.com/discussion/9137/a-modified-hybrid-winterizing-method-pump-toilet-shower
In my post above, I attached the bandb molders (the mfg) Nautilus manual. I found it quite helpful as it explains the function of the Nautilus and each valve well.
x
Portland, OR
Do you know why the Nautilus panel has the Red lever horizontal to winterize, if the White lever being horizontal prevents water from entering the Alde?
Or does only the combination of the White lever horizontal and Blue lever vertical prevent water from entering the Alde (in addition to the Red lever being horizontal, regardless of all other settings)?
edit: (removing old/erroneous diagram - see below for up-to-date correct one..)
- the output of the pump doesn't go straight to the cold water taps like in my previous diagrams. I realize now that the pump output actually goes to the blue handle *input*. I've updated the diagram accordingly below.
- @bergger's analysis makes sense to me now. Because the sanitizing liquid is going straight to the tank, and never hits the cold/hot/heater pipes, I can see that the red handle is meaningless. I think there might still be some reversal in logic in the emails above (horizontal vs. vertical position of the white lever), but I think those may just be a typo and everything else checks out.. @bergger maybe you can confirm?
That said, I feel confident the below should now be right logically - at least based on the manuals!
This is assuming that when the Nautilus is in "Sanitize" mode, it only suctions solution into the fresh water tank as was stated above, and not to the lines as well. I personally haven't tried this yet, and simply closed the Hot Water 'Red' valve when I sanitized my lines.
