I have a new 2021 TAB 320S with a stainless steel sink...I think. I've had it for a month or so and used the sink periodically without a problem. However the other night (in my driveway) I ran some water through the sink from my fresh water tank. I had filled the tank a few weeks ago with filtered water from my house. Today, after the TAB had been closed up for a few days, I went inside to see rust stains all over the sink. Some areas were quite deep and starting to pit! I know that some lower grade and martensitic stainless steels will rust....but I was really suprised to see this. Has anyone had a similar issue? I read on line that I might need to get an iron filter for my water source, but I've never had significant rust stains anywhere else. Any help would be appreciated.
0 ·
On the fresh water thing: at this point, given that you left it for a few weeks, you’ll want to sanitize that tank before using. NuCamp is recommending 1/2 cup bleach mixed with one gallon of water, then fill the tank with clean water and let it sit a time before draining again. Instructions for the 2021 are here: https://tab-rv.vanillacommunity.com/discussion/10932/sanitizing-de-winterize-2021-t-b-320s
Plan to sanitize at a minimum first thing after dewinterizing, and every time you leave the tank sitting with water for too long after a trip. Some people do it more frequently, some just once a season. Even if you don’t drink your tanked water, bacteria in it can aerosolize with sink or shower use, and therefore can be inhaled...a good reason to keep your water system clean!
Concord, NC
@Dutch061: Thank you. I understand the carbon contamination issue as well. It's just strange that it didn't show up until now.
After a trip to the west Texas desert where the water was extremely hard and left mineral deposits on everything it touched, a quick scrub with Barkeepers had the sink back to looking new.
In case this is of interest to anyone, I had my sink out this past weekend to change out the faucet, and was surprised to see that the sink is manufactured in Italy!
I would think StarSan would be a perfectly good sanitizer--and no rinse at that. The problem may be that you would have to use A LOT to completely fill the system in order to cover every surface. Unlike your fermentors, you can't just spray or swish a little around and call it good.
2020 V6 Chevy Colorado
