Fridge Won't Light for Nothin :-(
12345679»
  • jgram2
    jgram2 Member Posts: 1,522
    Thenorcoldguy.com, mentioned at the beginning of this thread, has a techie blog. Skimming the questions, there are several about the fridge not cooling, but I wasn't paying attention to the models being discussed. http://thenorcoldguy.com/norcold-technical-blog/
  • JasonC424
    JasonC424 Member Posts: 18
    Thanks Two J, I'll have a look
    2016 T@b 320 S
    200 watts Renogy Solar Panels
    2008 Toyota Tacoma 4 cylinder RWD
    Delaware, Ohio
  • JasonC424
    Additional note, last night I used the porch light and inside light and noticed that they were flickering a bit, kind of like a fluorescent lamp. I'm sensitive to light and especially to fluorescent, so it appears that this is something new.
    2016 T@b 320 S
    Delaware, Ohio
    Jason, adding a signature with your TaB year and model and your TV Is helpful.  Do you mean the main overhead light?  Were you on shorepower, battery, solar?  Depending on your model year, they may be LEDs or not.
  • JasonC424
    SAM, thanks for the response.  It's a 2016 T@b 320 S with 200 watts of solar.  We rarely plug into shore power, so are using solar and propane for our needs.  I believe that all the lights are LED.    I attempted to change my signature with no luck, but would be happy to add it if someone would guide me.
    2016 T@b 320 S
    Delaware, Ohio
  • jgram2
    edited February 2018
    @JasonC424 tap the settings "wheel" to the right of your user name in the black banner, select Edit My Profile, select Signature Settings  and add/change whatever. LAST, Tap the Save button !
    I do know that the porch light has the highest draw so I wonder if that had any impact?  Anything loose?  When that happens, turn on more lights and see if they are all flickering.
    ScottG Administrator Posts: 5,669
    @JasonC42, if your fridge ignitor was running full time, that I would almost expect your lights to flicker. Every time the ignitor clicks it places an increased load on the battery. The rapid load fluctuations are evident in voltage sensitive devices such as lights.
    In short, I suspect your flickering lights are a side-effect of your fridge problem.
  • mona
    mona Member Posts: 246
    Forgive me if this has already been mentioned. Have you tried replacing that fuse?
    Jeannie
    2015 T@b S Max  white with silver trim. 2018 GC Trailhawk.
  • jkjenn
    jkjenn Member Posts: 6,423
    Jeannie
    Jeannie - ah...yes, the fuse - good call.
  • JasonC424
    Scott, I would agree that they may be related.  The light flickered even with the fridge completely off, so I'm wondering if there is an issue affecting the fridge somewhere else in the T@b, would that be possible?
    2016 T@b 320 S
    Delaware, Ohio
  • JasonC424
    Jeannie
    Thanks Jeannie, we had a look at it and it seems fine.  Also we disconnected the wire leading to it and the pilot light went out and the ticking stopped.  My guess is that this means that the fuse was doing its job.
    2016 T@b 320 S
    Delaware, Ohio
    Sounds like a power fluctuation from something, but if it's not the ignitor then I'm out of ideas. My knowledge of the fridge circuitry is also pretty skimpy, so I can't say if the flickering is a cause, an effect, or a coincidence with regard to the fridge issue.
  • ericnliz
    ericnliz Member Posts: 4,437
    @JasonC424, Thanks for the update! I hope you're on the right track to a resolution! ;)
  • Verna
    Verna Member Posts: 6,876
    That’s great news, Jason!
  • jkjenn
    Excellent! Thanks for circling back!
  • FuzzyYanni
    FuzzyYanni Member Posts: 110
    Heads up for anyone needing to change their thermocoupler - back in Oct 2016 I sucessfully removed and replaced the thermocoupler on our T@DA 2009 FD without having to remove the fridge at all.
    Once replaced the fridge worked perfectly. So it IS possible !
    "I know one thing, I know nothing."
  • ChanW
    ChanW Member Posts: 3,165
    Cool, Fuzz. Thanks for that.
    Where did you find the thermocouple? I might want to have one on hand, just in case...
  • FuzzyYanni
  • ChanW
    edited October 2022
    Great @Fuzzy. Thanks!
    FYI, note that the Tab's down-the-road vibration can loosen the thermocouple nut. After tightening mine numerous times, I put a drop of blue Loctite on there. It's been fine ever since.
