BTW, camping etiquette would be a great topic.
Can you post some photos of the support and foam used?Normfun said:Similar experience with the black dual hose causing the problem. I managed to isolate and support the section causing the noise with some foam. All quiet now.
in the summer! The training never ends, and often makes you wonder who is training who!
J.D. & Sue
Ditto. I haven't run the Alde that much as it has slightly warmed, but last night and this morning it was much colder and windy.PXLated said:If all I need is hot water, I keep the Alde off until some time before I need it.
J.D. & Sue
"Jesse Can you forward this to Joe?
I havnt found a reducer yet like what is shown in the PP. But the customer could have their pressure adjusted in the short term. I also think the Camper is going to work better because the longer hose makes it work better.
We should establish this valve which can be added for High Altitude application. Its just a inline pressure reducer.
J.D. & Sue
That's a good question. Is there a sufficient heater that will run on my 75Ah, AGM battery. I can charge the battery with our 160 watt Zamp solar system. Will the Alde heat us up using the battery? We don't like the cold.PXLated said:Curious - If you won't have hookups, how do you plan on powering the ceramic heater?
