Alde Freight Train (Alde 3010 model)
2456715
  • Nomad
    Nomad Member Posts: 7,209
    Clang a cast iron pan next to me at 5:30am and I'm going to be ornery, coffee or not :-)
  • Tabaz
    Tabaz Member Posts: 2,420
    Highjack Alert!  We've gone from the Alde Problem to Camper Etiquette. :)  BTW, camping etiquette would be a great topic.
  • Nomad
    Semi Highjack - Topic = Noise :-)
  • Verna
    Verna Member Posts: 6,876
  • Normfun
    Normfun Member Posts: 285
    Similar experience with the black dual hose causing the problem. I managed to isolate and support the section causing the noise with some foam. All quiet now.
  • Tabaz
    Can you post some photos of the support and foam used?
  • Nomad
    Sounds like a simple problem to solve - isolate the outer/inner from each other - Have you passed this on to Alde?
  • Wanderoo
    Wanderoo Member Posts: 553
    Want to see the photos of the support and foam used!!!  That would be helpful, as I've experienced a similar problem with my Alde on propane at higher elevations.
  • Normfun
    I won't be near the trailer for a couple of weeks. But while making the noise just move your hand around on the black hose until you hear it stop. I just used some scrap memory foam cut from our topper. Wedged it in. Sound came back added another piece further along. And of course the third piece fixed it. I never took the other two out. I didn't want to jinx it. That was a year ago. No issues since. It's not science just trial and error.
  • Tabaz
    Where did you wedge the foam? Between the inner and outer pipes or between the outer pipe and some nearby structure?
  • jkjenn
    jkjenn Member Posts: 6,424
    edited June 2016
    You know I have stuff stored in the back section, behind the Alde and I think it helps dampen the sound. I had to run it this AM. It was under 40 degrees and my feet were damp from my morning shoot. It is nice and toasty, now. I am at 9,500' right now.
  • jkjenn
    I dropped to a site at 9,163' last night and no freight train. It was rather chilly here after the rain. I haven't been  running the Alde much, at all, but kept it on all night. Rocky prefers the heat.
  • Nomad
    Most people/pets do - Next thing ya know Rocky will have you trained to close your windows in the winter time :-)
  • ericnliz
    ericnliz Member Posts: 4,437
    Then 'ya have to re-train him to open them =) in the summer! The training never ends, and often makes you wonder who is training who!
  • Nomad
    It's always them training us - We usually don't want to admit it though :-)
  • ericnliz
    Isn't that the truth! Have had to change my sleeping-waking schedule for feeding times. Have, however trained mine to to adjust the volume on these issues. =)
  • DurangoTaB
    DurangoTaB Member Posts: 754
    We camped at 8200ft last weekend, and it was a mild freight train noise, enough to hear it 1-2 campsites away.  Woke me up, but not my wife.  The evenings were unusually warm, so we didn't have the heat on, but the Alde kicked on & off to keep the hot water hot.  Still no word from Alde US, Alde Sweden, or LG regarding a resolution.
    J.D. & Sue
  • Nomad
    If all I need is hot water, I keep the Alde off until some time before I need it.
  • jkjenn
    Ditto. I haven't run the Alde that much as it has slightly warmed, but last night and this morning it was much colder and windy.
  • Tabaz
    Durango - I emailed Alde a week ago describing my noise at altitude problem.  No response whatsoever.
  • GrandmasKid
    GrandmasKid Member Posts: 163
    I'll take some neoprene from an old partially rotted wader with me to the high country this fall to deaden hose noise with. I'm brand new to this so I need to know if the Alde will keep us warm at high altitude or do we need to buy a small ceramic heater? We plan to be between 6,000 and 8,000 feet up without hookups.  Thanks for your thoughts.
  • Nomad
    Curious - If you won't have hookups, how do you plan on powering the ceramic heater?
  • DurangoTaB
    @GrandmasKid...we've never had problems with the Alde running at those altitudes, just more "rumble" the higher you get (we live at 7,000ft).
    @OutbackAZ...I've never had good luck with ALDE U.S. (Portland/Vancouver), although some folks report otherwise.  I'll send you some notes offline that I got from Scott Hubble.
    J.D. & Sue
  • Tabaz
    Durango - looking forward to getting your notes.  I will be following up LG and Alde this week in an effort to get this resolved.
  • DurangoTaB
    Here's the 5/25/2016 headline of a long email I got from Scott; it echoes a comment ALDE service dealer comment at a big rig RV shop in Grand Junction, CO (to reduce gas pressure; his advice was to do it at the tank/wall).  Perhaps if we keep pressure on PV and ALDE (pun intended) they'll do something more definitive...
    "Jesse Can you forward this to Joe?
    I havnt found a reducer yet like what is shown in the PP. But the customer could have their pressure adjusted in the short term. I also think the Camper is going to work better because the longer hose makes it work better.
    We should establish this valve which can be added for High Altitude application. Its just a inline pressure reducer.
    J.D. & Sue
  • GrandmasKid
    That's a good question. Is there a sufficient heater that will run on my 75Ah, AGM battery. I can charge the battery with our 160 watt Zamp solar system. Will the Alde heat us up using the battery? We don't like the cold.
  • Nomad
    GrandmasKids - You'd run the Alde on propane. The Alde pump runs off battery but is pretty energy efficient. So, charging your battery via solar for the pump works just fine. I have a small ceramic heater but only use with a hookup as it'd kill my battery if run overnight. Anything that heats up - hair dryer, toaster, heater, etc - draw too much juice to run off the battery - unless of course you have a big battery bank.
  • Tabaz
    Durango - thanks for Ken's contact information.  I'll be sending him and LG a letter requesting help with this problem.  If it can be solved with an in-line pressure reducer, that would be great.
  • ChanW
    ChanW Member Posts: 3,165
    edited December 2016
    OutbackAZ, please be sure to update this thread with your findings re reduced LP pressure. It seems it could be a simple fix... (or not  ;))
  • source3
    source3 Member Posts: 144
    DurangoTaB.  Did you install the regulator?  If so, how about a show and tell?
    Andrew P.
    Durango, CO
    2015 S Outback
