The yellow arrow is pointing at the thermocouple attach point to the gas valve. Don't have a photo of its location under the burner, but you may be able to follow the line to it.
I guess I misunderstood your OP. Mine clicks, poofs, and then goes out while I'm still holding the red button. If I understand the mechanics correctly, that rules out the thermocouple. Sounds like it might be the fix in your case, however. Good luck!PXLated said:That's what happens - Light stays on as long as I hold the button in (tried up to 1.5 minutes) and goes out the minute I release it. Back on the minute I press it again.
YesPXLated said:Just to make sure we're on the same page Scott...
I get the faint clicking and a faint poof - The green light comes on and stays on as long as I hold the red button in no matter how long I hold it in. The green light goes out when I release the button.
Thermocouple?
Unless Norcold made things proprietary (ugh!) you should be able to unscrew the old TC at #1 and pull out the sensor tip on the other end.
Then insert whatever you found at the hardware store into the sensor holder and connect the other end.
If the replacement is too long you can leave a portion coiled up.
The hardware store probably had something like this: https://www.amazon.com/gp/product/B00076VET8/
Compare that to: https://www.amazon.com/gp/product/B0031XDV18/
Gotta love the price difference.
