Alde Freight Train (Alde 3010 model)
1235715
  • jkjenn
    jkjenn Member Posts: 6,424
    fwillison said:
    The regulator decreases the pressure from the standard 11 inches of water to 7 or 8 inches of water just to the Alde.  I don't think this is a real fix, but may be work around.  I could be wrong, but my understanding is that the proper fix is a change in jetting or orifice size.  The Alde seems to use a unique fuel supply to the combustion chamber, and I don't completely understand it.  Anyway, hopefully the lower pressure regulator works well enough.  Sounds like OutbackAZ may be first to install.  I look forward to seeing how it goes.
    So, will this create an issue for those who camp at both high and low elevation?
  • Tabaz
    Tabaz Member Posts: 2,420
    Marvin emphasized that this fix has not been tested at altitude, So it may not work.  I'll also try it here in Phoenix. Worth a try.
  • dsatwork
    dsatwork Member Posts: 744
    We're waiting with baited breath
  • fwillison
    fwillison Member Posts: 35
    Strange that it hasn't been tested at all at altitude.  Seems like a pretty simple thing to test.
    Jen: I do wonder about what happens at lower altitude with the lower pressure regulator.  Could be that it helps at high altitude but may cause some problems at lower altitude.
    Fred and Nicole Willison
    Tulsa, OK
    2017 Tab S Max Outback silver/silver
  • Tabaz
    Alde Fix follow-up.  I installed the additional regulator (see photo above) along the rear frame member.  The Alde produced heat and hot water here in Phoenix with the additional regulator.  Will take it up to 7,000 foot elevation this weekend for a test.  If successful, I'll provide more photos of the installation and some suggested procedures.
  • ericnliz
    ericnliz Member Posts: 4,437
    @OutbackAZ, Thank for the update. Please let us know how it goes with what you had to do for the install as well. Thanks!
  • ChanW
    ChanW Member Posts: 3,165
    Thanks OutbackAZ
    Is that their recommended location for installing it?
    It seems a bit exposed there, and I wonder about rubber hose too. I think ours is all pipe on the underside.
  • Tabaz
    Chan - yep, that's the location they suggested.  It's covered by the black plastic undercarriage panel, so not exposed to the elements.
    Here is the regulator before putting it in the brackets.  You can see the (very dirty) undercarriage panel behind it.
  • ChanW
    Ahh, I see.
    We're lacking that panel on our 2014 model.
  • Tabaz
    My 2016 (August 2015 manufacture date) has the black iron pipe ending about 2 feet from the rear frame member.  It has a brass gas fitting, then a long rubber hose that goes through the cabin floor, then to the Alde unit inside.  This regulator simply goes between the iron pipe fitting and the hole in the cabin floor.
  • ChanW
    Maybe I should look again. Might be the same on mine.
    I'm looking forward to the results of your test...
  • ericnliz
    Thanks @OutbackAZ, Did you have to make the bracket?
  • dsatwork
    That looks really secure and professionally installed....nice job. We are all hoping this works and I'm not even sure we'll have a problem. Heading to 5000 feet this weekend, but don't think that is really a challenge for this issue.
  • Tabaz
    NuCamp originally sent me photos showing the regulator upside down.  It would have been impossible to drill into the top of the frame with the brackets they supplied, so I drilled four small holes into the vertical side of the frame and used two "L" brackets.  I then sent photos to NuCamp who informed me the regulator was upside down.  Rather than drill four more holes into the bottom horizontal portion of the frame, I cut a 36" aluminum ruler into two sections, bent them in a vise, then drilled holes in each to match the first holes I drilled.  Came out very secure and will not interfere with the undercarriage cover.  I have about 5 hours into it.  Should take others about 2-3 now that we have prototype.
  • Tabaz
    Heading up north (6,600' elevation) later today to test the Alde mod.  I was planning on staying at an RV park with electric hook-ups just in case the Alde mod didn't work on propane (I could simply go to electric).  I assume I can simply turn off the electric source at the Alde digital control panel so that it runs on propane only even if on shore power.  Is this correct?
  • ColoradoJon
    ColoradoJon Member Posts: 415
    Yep, that's correct!  I'm very interested to hear your results :)
  • Tabaz
    Thanks John.  They have Internet, so I'll post how the Adle is working as the temperature drops during the evening.  My recollection was that the Freight Train Noise worsened as the temperature dropped.
  • Tabaz
    Update 4:00pm: so far, so good. 6,510 elevation, 60 outside temp, 115 degree heat coming from the rear deck vents, water very warm, Alde silent.
  • Ratkity
    Ratkity Member Posts: 3,770
    You must be sweating! 115F? 60F outside temp.. nice day! :)
  • Tabaz
    My laser thermometer reads 115 degrees of heat at the rear vents. The cabin is 75 degrees.  Had to lower the Alde setting, as it was getting too warm.
  • Ratkity
    Oh dear, you and your fancy tools (I want one!). :) Don't say anything about any exotic pieces of wood you find or V will hunt you down... :wink:
    Thanks for the updates!!
  • ColoradoJon
    Interesting... to be honest I wasn't holding out a lot of hope for this fix but based on your results it looks like it is at least plausible.  My Alde was silent during the walkthrough at the dealer in Colorado Springs, which is about 6000 feet altitude.  It's really noisy where I live at 8700 feet.  This looks like something I will have to try.  Can you provide information on the type of regulator you had to install?
  • Tabaz
    Success at 6,510 feet. 5:30 am, Outside temp is 36 with no noise.
  • Verna
    Verna Member Posts: 6,876
    @OutbackAZ, that is such great news!
  • Verna
    @Ratkity, I have one of those!  It's nice to have with a 60 yr old home with blown in insulation in the walls that is settling ;)
  • Tabaz
    Wish I could have tested this at a higher altitude, but time did not permit. Jon - no brand name or model number on the regulator. However, it lacked the warning about being installed outdoors that the regulator in the propane tub has (snap off the plastic cover). Let me know if anyone else wants to try this. If so, I'll post more info and photos.
  • ColoradoJon
    @OutbackAZ - I really appreciate the feedback on this, looks very promising.  I spend most of my camping time above 8000 feet and here in Colorado the nights get as cold as 50 degrees F, even in the middle of summer.  We always use the Alde and it is always noisy :)
    I'm definitely going to try this!
  • ericnliz
    @OutbackAZ, Thanks for the test results, and sharing. I do have a question though...What temperature setting did you have your Alde set at to get to 75* inside the T@B? Sounds like a great success story. Will you be sharing the info with the folks at the factory as well? Could be a great fix for a lot of "freight train" issues I've read about here. Still puzzles me how some folks have that issue, and others don't though. Any ideas on that at all? Thanks, Eric
  • Tabaz
    My tow vehicle external temperature just registered 29 degrees when I went for coffee. My dual Acu*Rite shows 31 after I moved it from on top of the tire (probably had warmth coming from the tire, resulting in a higher reading). Eric - my Alde temp settings may run "hot." If I set it to 70, the AcuRite reads 61 which is plenty warm for me.
  • ColoradoJon
    Mine runs hot as well.  I had to adjust the temp setting -7 degrees.
