ericnliz said:@OutbackAZ, If 'ya keep climbin', we're gonna have to send a space shuttle for a TV to fetch 'ya back!
Either that, or I'll send my sister with her Alto Camper (aka the Mothership) to go find ya. Thanks for all the info! fwillison said:......
What a simple fix.
Not sure why the install needs to be done the more complicated way recommended by the factory. This way is much easier.
Fred
OutbackAZ said:OK, back in Phoenix. Before everyone starts getting too excited about this mod, my results only reveal that it works up to 7,000' at 36 degrees. It would be great if someone like DurangoT@B could install it and test at even higher elevations. It's not a fun install - you're crawling around under the trailer and trying to maneuver in some tight spaces. But well worth the time and effort if it works.
fwillison said:Chan, I had the same concern. One of the other advantages of the simple installation is the ease of switching back and forth if necessary.
However, I am currently stranded in Colby Kansas in a blizzard. The first night I spent in the Tab in the Colby Walmart. I thought I might get blown over by the 60 mi per hour winds and driving snow, BUT the Alde provided adequate heat with the regulator still in place. Not sea level, but Kansas is not known for its mountains...
Fred
jkjenn said:
One of my dreams is to be stuck on the plains in a blizzard.
Some suggestions for those of you going to do this mod:
Wash off the plastic underbelly cover before starting (lots of dust when putting it back on).
You only need to remove the cover screws up to the tires for adequate access to the year frame member.
A one-piece "L" shaped bracket would be better than the two-piece supplied by the factory.
Drilling into the bottom of the frame may result in the plastic cover not fitting at the bracket (the bracket screw heads may protrude into the plastic cover).
Ensure that the spacing between the factory brackets results in the clips catching the brass fittings on the regulator (not the male ends of the hose attached to the fittings).
The "tower" on the regulator with the brass "VENT" stamping must face up (towards the sky).
The stamped arrow on the regulator must point to the Alde unit.
Ensure the propane hoses do not touch the top of any screws from the plastic underbelly cover! (I zip-tied the two hoses together to get them off the bottom of the frame, also used a shorter cover screw, then even filed the top of that screw smooth - just in case a hose would rub against it).
After testing all fittings with soapy water, fire up the Alde on propane and see if it works. No need to do any bleeding of lines - mine started working immediately.
Hope this helps.
dinzzy said:I had the same issue and this was my fix. The vent to the outside is both exhaust and intake. There is a metal flex tube for the exhaust that is mounted inside a plastic intake hose. I discovered that the plastic hose was vibrating and striking the metal exhaust hose. (The rattling noise). I loosen the clam on the plastic hose from the unit and pulled it as far as I could on the sleeve it was mounted to, giving me more clearance, and then thightened it up. No more noise! I would like to install a longer hose to get more clearance but the dealer has not been able to get me one as of yet. Hope this works for you and others.
