I haven't yet purchased, but am very interested in T@B 400 and hoped to tow with Honda Pilot (5,000 lb tow capacity, 500 lb max tongue wt). I see T@B 400 has 460 lb tongue wt, so this seems too close for comfort/stability/safety. I see on "Travels with Delaney" YouTube videos they use Toyota 4Runner (5,000 lb tow capacity), which in the owners manual states tongue weight should be 9-10% of gross trailer wt, which for T@B 400 seems would be in the 360-400 lb probably (wet wt + supplies/clothing/tools, etc.). So, to me looks like Pilot is very marginal, and 4Runner would be undersized regarding tongue weight. I didn't want to have to drive full time (towing and daily use) in a pickup truck or full size SUV. All thoughts and comments welcomed.
0 ·
Asking for an opinion here you will get all sorts from completely unsafe to bullet proof safe. You are the one who has the final decision.
On paper your setup should be fine. But you are the one who has drive it and if you feel unsafe you will always be second guessing your ability to tow. So it sounds like you would be more comfortable in a different TV.
As homebody pointed out from a 5k tow vehicle the next step is 7k. without getting into a pickup truck or full sized SUV I am not sure of other options.
A thought would be to rent a 400 for a weekend and drive it a nearby campground and see how it goes.
I am a pickup guy so I would say get a crew cab midsized pickup and go. but that is just me
Since the water straddles the axle almost directly under the stove, carrying a full tank of water shouldn't hurt and might even lighten the tongue weight a bit. Any grey or black water would increase the tongue weight as would any pretzels, Bourbon or trail guides stored forward of the stove. When trying to balance the load, the black tank is closer to the front than the grey tank but both are forward enough of the axle to directly impact it. To sum it up, clothes and weight in the cargo area lightens tongue weight, the refrigerator and closet are balance neutral and everything forward of the stove adds to tongue weight. I know the engineering is more complex but for this purpose, the comparisons should be apt.
This made us focus on the tongue weight capability of the two vehicle. Most salespeople and owners talk about towing capacity and flat-out ignore tongue weight except perhaps to talk about a minimum rule-of-thumb required on the hitch to minimize sway. The tongue weight of the Toyota 4Runner is 500# and it has a 5000# towing capacity. By comparison, the tongue weight of an F150 is also 500# although it can go from 7500# all the way to 13,000# depending on configuration. The key point which was surprising to me, was that if you duck your head under the hitch, you will see a sticker showing the tongue weight capacity with and without weight distribution. While the 4Runner is maxed out at 500# and requires a WD hitch to reach that capacity, the F150 can go north of 1000# pounds but requires a WD hitch to do so. I couldn't believe what I was seeing on the F150 so I chatted with Ford and after 30-min of back and forth telling me about tow capacity, the admitted that nobody ever asks that question and found someone in engineering to confirm the 500# limitation without WD.
Since the nuCAMP is a "C" channel frame for which a WD hitch isn't advisable, there is another thread where the factory posted their recommendation to use a "bolt-on, link style" on Page 4 of this post: https://tab-rv.vanillacommunity.com/discussion/6219/tab-400-weight-distribution-hitch-not-recommended-due-to-c-channel-construction/p4
That still left me as a 4Runner owner with a 500# maximum tongue weight so switching vehicles became a necessity as I felt uncomfortable being maxed-out in optimal conditions and overweight if I brought too many bags of carrots or a bit too much Bourbon and left it forward of the stove. The F150 with Max Tow is a great contender and with a bed cap, offers the best of all worlds in that you can carry spare fuel & firewood in the back which isn't advisable in an SUV. The only SUV I could find with a tongue weight greater than 500# that didn't need a WD hitch is the Ford Expedition at 600# hitch and 9020# towing capacity. The SUV offers enclosed space and is 2 feet shorter than the F150 while being less expensive purchased used than an F150 but having a smaller gas tank at 28-gal .vs. 36-gal for F150. Admittedly, I was focused on the F150 due to my need to carry large dogs and the seats don't fold flat in either the GM or RAM. Still deciding between these two vehicles.
Your research may vary but should you decide upon a used car, this website which takes depreciation into account helps figure out which model year is the best financial decision for a specific model & year for a used vehicle. Glad someone took the time to do all that work because it was enlightening and helped me decide. http://usedfirst.com/
Lastly, I've been looking for something in the 200" length but felt that the 4Runner up steep hills at 45-50mph was just a bit under-powered with the new 2019 trailer so I looked at the engine capabilities. The 4Runner has 270-hp at 278-fp torque so I compared it to the similar sized Honda Pilot at 280-hp at 262-ftlb torque. My guess is the 4Runner and the Honda Pilot will have similar performance characteristics on the road so I decided to look one size up from the mid-sized. This isn't to say the Pilot won't do the job, only that with my 4Runner it was marginal and that was before I loaded it with people, dogs, water and so forth. YMMV.
I see so many folks on the forum who quickly realize that the 320 is too small, I am glad when someone recognizes the space constraints in advance. But, I wonder how the sale of the 400 has impacted the sale of the 320s?
Keep doing your research, if the T@b 400 is what you really like you'll find the right TV solution for you.
Have you considered the Jeep Grand Cherokee ?
nüCamp: 2019 T@B 400 Boondock Lite
New surprises everyday
See beautiful world
One thing we've found with RV's, everything is a trade off ...
2022 Ford F350 Tremor | 2022 Cirrus 620
just one thing here, is that towing a trailer with a empty bed pick up make the back of that TV really light. Witch can start to act funny in side wind, slippery surface and emergency manovers.
perso, I would go with the same capacity SUV anyday of the week. And way more confo and secure cargo space.
if you do not need a pick up. Don't get a pick up.
This is me, all my younger years, I wanted a pick up, when I finaly gor one, I realised that a 4 wd station wagon of a wd SUV was more my type and way more practical for me. I simply use a trailer when needed to.
but this is me. Do what suit you.
Have fun outhere.
TV 2005 jeep TJ unlimited
Alaskan Malamuthe on board!
